I have two RB 13T's.while fitting the pre turbo piping, I had to remove the rubber reducer ring from the stock pre-turbo intake piping to get them to fit over the new compressor inlets. I noticed while looking at the 3sx pre turbo intake pipes that only the 19T's and DR750's are supposed to have the 2inch inlet. Is this something Rob changes on these? the compressor serial is 49377-04300 which is TD04L 13T/6, I didn't buy these direct from rob, so idk what all he does to them any help is appreciated thanks.
"The spacers are required for stock turbos, 3SX Eliminators and Executioners, 13g/13t, 15g, 16t, DR550, DR650, and other "stock housing" TD04 turbos.
The 19T and DR750 turbos have a modified compressor housing inlet with a 2-inch outer diameter, so the coupler will fit right on the turbo without the use of the spacers." this is direct from the 3sx site.
Just a larger compressor housing. If you're worried about dust getting in there, do a couple of wraps of shrinkable electrical tape on there to seal it up nicely without folding. Of course this is assuming that yours are stretched like most I've seen
