Once you get the belt on, and BEFORE you release the tensioner pin, turn and tighten down the tensioner pulley on the front side of the belt so that the belt is quit snug. This should hold everything in place while you turn the engine over twice to bring everything back to the correct position with the crank gear lined up where it should be. Then double check to make sure everything aligns up starting with the front cam gear working your way to the back ones.
This way you do not have to remove the tensioner and re-compress the pin every time to adjust the belt until you get it right.
If all is good you can loosen the belt tensioner pulley and set the right amount of tension so that when the tensioner pin is pulled out the shaft should not move and you should be able to re-insert the pin easily or very close. Be careful not to tighten the belt tension when you are tightening the tensioner pulley bolt.
There should be about 4mm of tensioner pin sticking out and touching the pulley tensioner lever when the tension on the belt is correct.
