Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Aluminum 2 Piece Drive line question
    Quote Originally Posted by Chatzvr4 View Post
    It just comes down to cost. because of the length of the drive shaft you really dont want a one peice in aluminum. it is said it will vibrate to much. to build a full two piece aluminum would basically mean two drive shafts doubling the cost of the drive shaft. We found a company locally over here that have begun building ours for us. which will be aluminum front and rear shafts. We will start putting them to market after we test them out. we should be hitting the market for under 850.00
    any possibility of getting one with the nipple to fit the w4a33 xfer case?
    Just couse your always a pain in the arse IPD.
    1996 GTO, Owner since 2003.
    you DO realize that the front section is pretty much the only difference between 6-speed and atx driveshafts, right?
  4. #24
    Forum User supporter
    Oct 2010
    Rosemead,Ca
    the only way would i could do that is to have the specs of your yoke or the actual piece
  5. #25
    there are what...2 people who attempt to do some sort of performence increase on a ATX BOTH of them are PITA (hello Nelson, just joking )
  6. #26
    ...working on getting a spare of that piece.
