Results 11 to 20 of 42
Thread: Using MAF Translator with SAFC 2
    Midland,MI
    I have the car tore apart right now waiting for my 19t's. I was thinking like 680's. I have it tuned with the afc for 550's right now. I will be buying the translator and sensor within the next month or so. It's snowing here so no reason to rush.
    seize the carpe!
    You should be fine, I'm running 600cc injectors at the moment with the same setup.
    VR-3747 :D Not Verified
    Dayton Ohio
    lithium, i saw the 2-step video ray made... could you make one of yours? it took a while for him to build boost, and im curious if you lean it out some if it could build a bit quicker?
    i have the exact same setup ray does. i havent tuned it yet because of a couple other issues. hoping to have it back up and running by next spring... aiming for 10's!
    it actually can build boost faster than the vid showed because i didnt have my foot into it enough there.
    Gilbert, AZ
    So the old MAFT is the way to go with a SAFC II. The MAFT GEN 2 isn't as good or simple as a old MAFT and SAFC II?
    Just wondering but why a MAFT?
    Absurdum est ut alios regat, qui seipsum regere nescit
    "De Oppresso Liber" - "Nous Defions"
    seize the carpe!
    I will see what I can dig up for you, I actually set my low throttle at 50% because I'm really only going to use that profile at the drag strip. Once Ive reached the 60' mark I'm going to be full throttle anyway. I really haven't spent much time messing with it but I was hitting 8psi on 16ts within a few seconds.
  8. #18
    seize the carpe!
    Quote Originally Posted by DrkZide View Post
    It allows you to use a GM MAF, thus allowing you to go blow-thru and vent to atmosphere properly.
  9. #19
    seize the carpe!
    Quote Originally Posted by mikeyVR4 View Post
    The basic MAFT is simple and easy, The MAFT gen 2 and Pro are great too considering you can log and use them as boost controllers as well. To be honest I just got the MAFT because I wanted to go Blow-thru.
  10. #20
    Is that the only reason? To run open atmosphere? Or is it good for running larger injectors too?
