Page 1 of 5 123 ... LastLast
Results 1 to 10 of 42
Thread: Using MAF Translator with SAFC 2
    Forum User Not Verified Feedback Score 3 (100%)
    Midland,MI
    Can I do it and what would I set the "sensor type" to on the SAFC2?
    August 2009
    San Diego, CA
    Yeah you can do it, this is what bboyalan did on his vr4, you set your maf translator for a base tune and you can go blowthrough and you have your afc2 for a finer tune. You can also add in an SITC if you want timing control.
    https://car.social
    i do it on almost every build
    Midland,MI
    What do I set the sensor type on the SAFC to? Hotwired? It's been tuned with the SAFC already so can I just leave the knobs on the Translator zeroed out?
    Forum User Feedback Score 0 mikeyVR4's Avatar
    Gilbert, AZ
    Would it be better to use the MAFT with SAFC 2 or just using the MAFT Gen 2?
    I just left the MAFT zeroed out and used the AFC for all the tuning, works great.
    Quote Originally Posted by Lithium View Post
    This is the way to do it. I use the maf translator to set the injector size then tune with the afc. You still set the afc to karman.
    I still like the older maf translator best. An afc has great tunability and even has 2 maps. You can't beat it... its just so simple
    ^ I'm really enjoying my SAFC2 now that I watched your anti-lag you tube video lol! I have one profile for my regular tune and the second profile set for when I need to embarrass someone.
    Midland,MI
    So can I run bigger than 550's with the afc if I set the injector size on the translator?
    ^yes but I wouldn't go crazy. Use the MAFT to compensate for the bigger injectors and then use the AFC to fine tune everything. Post a picture of your setup, Its always fun to see others blow-thru setups.
