Results 1 to 10 of 11
Thread: Scanmaster+lc-1+palm
    Forum User Not Verified Feedback Score 0 rawavr4's Avatar
    Easton
    Does anybody have this logging set up? And how do you like it? I have the SM3, I want a wideband, and I want to be able to view full logs.
    August 2009
    San Diego, CA
    I have a SM3 and Palm M500, I am not quite sure what lc-1 is but I run the two for datalogging and I have a wideband but i rarely look at it, the SM3 is for live feedback of knock counts and the palm for storing at all times, audible alerts of knock counts so if I do a wide open throttle and if knock over 6 counts my palm will alarm me with out me having to take my eyes off the road, my car is so well tuned so that I do not have to worry about that though.
    https://car.social
    Easton
    The lc-1 is just a wideband. I plan on plugging the wideband into the scanmaster so it shows real AFRs and knock counts. I'm getting tired of guessing my AFR with the NB02 on the SM3. How much did your Palm run you?
    Rashad, I think I have a palm at the garage I can sell ya cheap. I'll have to make sure it works first.
    August 2009
    San Diego, CA
    Quote Originally Posted by rawavr4 View Post
    I pieced mine together.
    17 dollars for the palm m515 off ebay used this was a real good deal
    15 for the y cable from 1glink.com this will charge it and datalog at the same time
    5 dollars for the adapter RJ45->Serial
    7 dollars for the usb 12v charger
    How would you be able to plug your wideband into the scanmaster? Would be nice to show that instead of narrowband.
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Check the link in my sig
    Easton
    Just read the writeup. Seems very simple. Give the lc1 fuse power, wire the lc1 output to the sm3 input, ground the rest of the lc1 components, then calibrate the wb. Does that seem right?
    ~2006
    Yep, pretty much. Just have to make sure the LC1 reading on the SM3 matches the reading on the laptop using the serial connection (ground offsets may cause a difference between the two values so you may have to scale it differently).
    Easton
    Alright cool. I just ordered one from the same person you got yours from. $143 shipped with sensor. Hopefully I'll have it installed by next Sunday.
    ~2006
    Let me know if you need any help!
  • History
  • Information
  • Groups
  • Events
  • Resources
