Can someone please give me a brief how to?
Brief how-to:
1. Remove drivers side front wheel
2. Remove crank pulley, and remove/break off the lower timing belt cover.
3. There are 2 bolts holding the sensor, I believe they are 10mm.
4. Swap in new sensor.
Fairly easy. Sometimes youll have to manuever around the trigger blade wheel to get the sensor out. You ll know what im talking about when you get the crank pulley off.
