Oh, you were doing those diagnostics with the y-pipe off. That makes a lot more sense now. Both of those slots bypass the throttle plate. One is for the iac and the other the fiav. Without coolant, the wax ball would never melt to close the fiav side so you basically always had the throttle partially open. You can block off the fiav side with a plate or something like that if you don't want to deal with the tbe hoses. You do lose automatic high idle at startup though.
