Okay, so I'm not leaking oil, or any other liquid for that matter. When I start the car, the oil pressure goes high until it warms up, which isn't a problem. But after the car gets up to temp and has been run for a while, the oil temp drops. Like droooooops down to about 2-3 bars on the stock guage. My idle is normal, though it goes from lean to normal (round 14.8ish), but the idle stays at almost the same rev range (1K-1200). I've checked all vac lines and all the oil lines I could see without digging into it. Any ideas as to what could be causing this problem? Is my pump going bad? Is it a vac leak that causes the pressure to drop cause fuel is being cut? Any input is appreciated.
