Results 1 to 9 of 9
Thread: all i hear is a click and fuel pump whine....?
    Pueblo, CO
    ok, well got the click click start relay in today, installed it and same thing. Just clicks and I hear the fuel pump whine. I checked the ign connector and it was tight (both screws). Checked the little white piece that spins inside the ignition switch, fine...I guess it could only be the starter? Any thoughts? suggestions what i might have overlooked?
    I just turn the key and hear a click and the walbro whining...
    Pueblo, CO
    I know there is a ign fuse in the fuse panel under the hood but have no idea if its blown or not becuase its a big black bastard?
    Banned J. Fast's Avatar
    Turn on the headlamps w/brights, press the clutch in, and turn the key. If the lights don't dim while the key is in the forward cranking position the starter is bad.
    Newark, DE
    There is a way to check if starter relay is bad per manual, and the relay can be jumped per this thread:
    http://www.3sgto.org/showthread.php?...=starter+relay
    When I had this problem I was hardly getting a click IIRC, and I removed the click click click relay mod.
    Pueblo, CO
    anyone else have any ideas?
    Get a cheap used starter off the boards and try it (I might have one). Also you could try banging on the starter with a hammer. That works sometimes.
    94 3500gt vr2? verified
    NC
    bringing back from the dead... any resolution to this? i have a few ideas if it's still a problem
    I'm Kind Of A Big Deal
    Get a bar, and whack the starter a few times. If it starts after that, you have a bad starter.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    Pueblo, CO
    lol ya this is old . It was a seized up starter. I got a new one and all good
