Be careful with the battery tenders and your ecu if on the same circuit. I think it was AEM or? that was getting fried from battery tenders. Might check further into it. I think I read a thread on 3sidiot....
Yeah, that's the thread.
It has been awhile since an update, I was waiting for things to come in so I could keep progressing.
The hold up was:
That is 1"x 1/8" x 50' neoprene whether stripping. If the interior trim touches the chassis or overlaps itself, this stuff is a gasket to attempt to eliminate rattles.
Here is a couple shots of places I installed it:
I also placed everything in the hatch area to check for fitment and to secure the battery tie-down panels to the chassis.
The third amplifier will be on a pedestal centered and above the other two amplifiers.
Then I was able to carpet and place my distribution blacks that I will have no need to access after the install is complete. I was also able to start running power wire, I forgor how much of a PITA it is working with 1/0GA. All of this is underneath the amp rack board, so look now once covered it is hidden for good or until I need to fix something.....LOL
Lookin really good, I need to bring the wife out one of these weekends and supervise () while you work on this beast lol
Or run some wires through my driver's door for my window module![]()
Steve, you're going to use that stuff on your hatch trim, too, no?
That's where the only rattles I have are coming from.
Oh yes I will be.
you listen here, you. this thing better be at NG and it better be sounding good.
i know where you will be sleeping...
