beyond that....what do you think?
I will use heat as well as a stronger glue and report back.
Please do seems like a neat project.
Sent from my DROIDX using Tapatalk 2
I was hoping you would chime in
I have found that contact cement is also used in the upholstery industry.
weldwood is contact cement, its not the same consistency as the stuff you can buy at home depot tho, the landau top adhesive is awesome. Best method is to use a cheap air sprayer i/e one of those $20 air guns they have at harbor freight. Give it a nice thorough coat on both sides, let it tack up for about a minute and it will hold and not let go, but be careful and go slow, because its an absolute bitch to pull off if you want to start over again. Use a heat gun too.
