Very nice! I love the finish! Ill be glassing my a pillars too.
How do you like the off axis mounting?
I have an idea on what works for my tweets.. Im just getting an idea on what works for our car.
I have not heard them yet and every speaker is different, my research revealed that the tweeters to this component set up sounds VERY good at off axis positioning. I am sure my T/A will make it that much better.
Also yes this was fiber glassed, but then wrapped in a automotive vinyl that matched the original vinyl wrapped A-pillars to appear like stock.
Nice to know
Question about the pillars.. Did you remove all the factory vinyl before you attached the rings and dowels?
I used non-vinyl wrapped A-Pillars. and the tweeter was a cup that I used non hardening model clay as a temporary adhesion to attach the cup to the A-pillar to find the ideal location, from there I screwed the cup to the permanent location.
Since this was not a huge area to build up, filler like tiger hair was used to form around the cup.
BUT if you was to use pieces that have vinyl, I would strip it first.
I need to address my bandwidth use, I think it was my signature on this forum, I have it hosted here now, and deleted off my Photobucket account.
I did a test install of the driver's side to make sure that I was happy with the rotated position of the faces of the gauges:
Now to start preparing the wiring so I can get this installed.
Routed the wiring for under the driver's A-Pillar, I extended all pigtails so that the connections will be in the dash, not behind the A-Pillar. This will be easier to install the part and not have to guess if I am pinching wires.
ALL wires are laying perfectly flat so that they will fit between the plastic and the A-Pillar:
Gotta love Gorilla Tape when running wires![]()
The stuff sticks so well.
