Originally Posted by
GTOJOE
Do you have a test light or a multimeter? if so you need to test the wires on the reostat for power after you turn the parkers on. So if using a test light clip one end to a good earth then just probe the wire [or the exposed pin in the socket etc] with the probe and it should light up. Turn parkers on and off to make sure this source is only on when the parkers are on. Same sort of thing with the multimeter. Connect the gnd/blk probe to a good earth then probe the wires and check for voltage of 12+ volts. Make sure your multimeter is set correctly as wel. DC volts with the = except the bottom line is actually 3 dots [ ... ] and select 20 volts or similar.
