Are you talking about the snap ring (there's one on in each end of the physical shaft), or the bearing race (the rings pressed in to the case at each end)?
The bearing shaft. Its the top of the shaft inbetween the input and the output shaft. I talked to 3sx today and they said as long you can make it flat again I should be able to reuse it. Is that a good idea?
Ok so I need some help... Again. I talked to J_Parker about this too. So I finally got my tranny back together but there's 1 bolt that is not going into place. Its that long bolt on the end case that is on the side. It doesn't catch on anything. And when I looked into the hole I just saw a bunch of metal. I'm going to have to take the bitch apart again aren't I....
The bolt locks the shaft carrier for reverse. The end cover side bolt has to be aligned with the reverse carrier and reverse shaft and installed on the end cover while it's opened. The bolt keeps the carrier from spinning. You might try to manually put it in reverse and spin the input shaft and see if you can get it to rotate into place but I don't think it will work if the carrier and carrier shaft aren't lined up.
More than likely you'll have to take it apart and set the side bolt unless you don't ever intend on using reverse again and never plan on parallel parking. Sorry for the bad news. Atleast you caught the mistake and didnt strip the bolt and damage the carrier. It was your first time rebuilding a trans and it's a simple fix so don't get too down on yourself! If you need anymore help post on up.
What trans sealer did you end up going with?
Okay, so I whipped up a quick trial and error thing on mine just now. You can spin the shaft carrier if you put something in there and spin it, I used a small flat head screw driver to spin it, it was time consuming but I got 'er. However I think it'll be faster than a teardown. Just don't use too much force on it as to cause some shavings, if you find yourself using some force to move it unfortunately a teardown will be needed. Also, because it's a partially floating carrier, you'll have to "shimmy" the bolt gently to lift the carrier in it's countersunk position. Sorry it took so long man, I've been three Provinces away from home for the past two weeks lol.
To J. Fast I ended up useing... What the hell is it called.... Ultra Black RTV silicone gasket maker. looks like its going to do a good job so far. Everything is back in place. The only thing That sucks is when I was bolting everything back down appearently a lil to much rtv got into the bolt holes so when i was tightening 2 of them chunks of the tranny came off. They don't look like there are anywhere that would cause a leak so I just put a lil RTV on those spots. I've been talking to J_Parker but now my problem is getting the shiter assembly back into place. I'm going to go mess with it some more but its a bitch. Any other tricks to getting it in anyone?
So after a couple hours of many many curse words and breaks i THINK its on right now. The plate is flush with the two guids and the holes for the bolt. I can move it freely up and down and spin the shifter right and left. I think its three levels. But how do I know that the spinning thing didn't move. Or if it was outta place I couldn't spin or move the shifter assembly up and down?
***EDIT***
Thanks for the response guys. I hope yall had a merry chirstmas and happy holidays. May your new year be profitable and good for the family and the car.
One thing That I have noticed, I looked at my other 2 trannies. The shifter is in the middle level. Meaning it can be pushed down and put into gear or pulled up. On the one in my room its seated all the way down on the plate. I can run through 5 gears but its not in the middle level like my other 2 trannies. Its not in right is it?
Sounds like the return spring may have snapped or come off. Those are hard to come by. I don't think you can buy just the spring. I think you have to buy an entire assembly to get one or buy one used from Kormex, Jack, or 3sx. Here's what I discovered... you can swap the return spring out with a duromax automatic trans friction plate spring. Usually when you tear apart an automatic trans you just toss crap out since everything usually comes in a rebuild kit (springs included). Turns out they can actually be used. They're roughly the same diameter but the duromax has a few more coils so you have to cut it down to length. The coils are a little larger in diameter but it works just fine. It makes the shifter return like a diving board. I broke mine and didn't have a part number so I went over to a buddy's trans shop and dug thru some junk drawers looking for springs (probably had 30 different ones) and that was the one that lined up the best and seated properly. All I had to do was cut it, file the end down, and heat one end to flatten it out so it seated flush.
So what if I just got the shiter assembly outta my tranny that I'm dropping from the car. The one that has a cracked mid case and installed it in my tranny. I can do that. But I don't know when I could have lost the spring. When I remove the shifter assembly from the tranny how would I know if I drop it or not? Is it just a spring on the end of the shifter assembly?
There's a tranny shop right next to my house. I've been thinking of taking it to them. At this point would it even be worth the gas cause I know I'm just being lazy...
If you have a spare trans you could definitely steal the spring out of there as long as it's not damaged. Do you remember putting the spring on the rod or seeing it on there when you put the shifter assembly back on? You might try pilling the assembly again and using a flashlight and looking around in there for the spring and then fish it out with a magnet.
