Results 11 to 20 of 22
Thread: Installing new radiator tomorrow. (koyo)
    Man vs 3/S verified
    Kingston, WA
    Quote Originally Posted by mb7050 View Post
    I know that thread some valuable information there...
    "With the mugen it warms up quickly to 163F then hangs there for awhile until it warms up the radiator. Once everythings warmed up it runs about 172-178F while moving. When I'm stopped the temp goes up some but comes right back down as soon as I start moving again or the first fan kicks on low. "
    "Yeah...I don't have those fan swicthes on a 96. I think its all computer control based on the ECM's temp sensor in the water housing.
    I'm not too worried about it. If I idle for a LONG time it will finally get to 204F and kick on the first low speed fan for a 45 seconds or so until temps get down to about 196F. As soon as I start moving temps drop back down to the low 180's when its 85F outside. "
    If the fans dont turn on as often as before with a stock radiator it doesnt really have any detrimental effect on the car. Operating temp might be a little lower but thats OK. My car does the same thing, MB. My fans never turn on unless I am at idle for over 5 minutes or so. I dont have an accurate water temp gauge but I have logged my coolant temps during crusing and they are in the low 180's just like yours.
    Gilbert, AZ
    My install went without any problems but just took some time to get things right. As like other have said, WATCH OUT FOR THE BOLTS ON THE AC CONDENSER. Overall, the process was easy and went very well. I am in Arizona so I know all about hot weather unfortunately.
    I have the same koyo and when I installed it I didnt know about the condensor bolt,
    poke I nice hole in the koyo and had to jb weld it.
    Gilbert, AZ
    Ah that sucks man. Yeah we used a rubber mallet and softly moved the condenser so we had no clearance issues.
    Is that condensor bolt a second gen thing. I will be installing a koyo next week and have pulled the radiator in and out more times than I can count. Can't think of anything like that.
    Gilbert, AZ
    Quote Originally Posted by vr3.9 View Post
    Yeah its more of a second generation issue but I would still make sure you have clearance if you have a 1st gen.
    Check out 3SX's site which shows pictures of the AC condenser bolts sticking out.
    http://www.3sx.com/store/comersus_vi...?idProduct=585
    Mine actually had a point on it. If I wasn't paying attention it would have easily poked a hole in it.
    wanderlust
    Chi-town/ATL
    didnt poke a hole but rubbed/bent fins so shaved down for peace of mind. i heard it's worse on second gens.
  9. #19
    Gilbert, AZ
    Quote Originally Posted by mikeyVR4 View Post
    AC Condenser Bolts
    radiator-install-mods-condenser-bolt-07-gen1-adj-300.jpg radiator-install-mods-condenser-bolt-04-gen1-adj-300.jpg
    Gen1 1991-1993 3000GT/Stealth Gen1 1991-1993 3000GT/Stealth
    radiator-install-mods-condenser-bolt-02-gen2-adj-300.jpg radiator-install-mods-condenser-bolt-03-gen2-adj-300.jpg
    Gen2 1994-1999 3000GT/Stealth Gen2 1994-1999 3000GT/Stealth
    All images from http://www.3sx.com/store/comersus_vi...?idProduct=585
  10. The Following User Says Thank You to mikeyVR4 For This Useful Post:
  11. #20
    If you installed a pressure gauge on the cooling system you'd realise that the headgasket is leaking, as they do eventually on all old cars.
    Steve
    I had my cooling system pressure tested (24psi) just about month ago no leaks .
