Results 1 to 6 of 6
Thread: RedLine Oil Recomendation
    CT
    Redline has a new web tool where you put in your cars make/model/etc and it tells you what redline products it recommends.
    For a 93 NA 5 speed I got
    recommended motor oil: 5w30
    recomended transmission oil: MT-85 (75W85) GL-4
    Thought that was interesting. I recently put redline 10w40 (from 15wSomething Mobil 1) and the difference was ridiculous, not a single lifter tick after the first 1.5 seconds of startup after the change, even with cold mornings starts. Engine feels great. I might try the 5w30 afterwards to see how that works out, but redline is a bit of an expensive "experiment".
    I was suprised to see MT-85 instead of MT-90. I'm actually staring at 3 quarts of mt-90 that will be put in the transmission tomorrow.
    The numbers arent too different so im not worried, but I figure since oil is always a hot discussion id bring it up.
    Incase anyone is wondering for a vr4 it says:
    recommended motor oil: 10w30
    transfer case: MT-85 (75W85) GL-4
    rear diff: 75W90 GL-5
    you know you like it Not Verified
    Sacramento CA
    Its basically just pulling the recommendations from the manual nothing magical about it.
    but if you risk running it rich they will recommend 5w40 but thats what I use anyway .
    Sacramento CA
    UOA has shown that 40wt is a better choice for the VR-4 anyways. 10w-40 or 5w-40 should perform very similar with the 10w-40 being in theory more stable.
    MT-85 is a product that just recently came out. They designed it for tranies like ours that require 85 according to the manual, but up umtil now we have all used MT-90 because thats all they had, and it works great.
    And the list goes on...
    CT
    Hmm maybe ill keep my 10w40 in there, and the mt-85 for next time
    Also need to find my copy of the manual haha.
