Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: TT Conversion SAFC Setting Help!!!
    Medford OR
    There are two correction factors, As you have yours at 20% and 80%, anything under 20% throttle will use the low throttle correction, anything over 80% throttle will use the high throttle correction, anything in between will be interpolated by AFC somewhere in the middle.
    I think your mistake is trying to use the wideband to tune in closed loop. You should only use the wideband to tune open loop operation. In closed loop, you're looking for happy fuel trims(100%)
  2. The Following User Says Thank You to RealMcCoy For This Useful Post:
  3. #12
    Never finishes any verified
    Wake Forest, NC
    OK Now that makes sense. Thanks!
    So how do you determine when you are in closed loop vs open loop? I checked Stealth316 and Jeff states that closed loop is during cranking, warmup, strong acc/dec and heavy load.
    Taking it to a shop is out of the question right now. The closest shop I would trust to do this is 3SX and they are 3 hours away. So I have to get at least get a basic tune on the car in order to drive it to 3SX.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  4. #13
    Apr 2012
    NorthEast Kingdom
    Interesting story - so what was the end?
