So I figured I would catalog my build on this site also.
I just picked up my friends 240sx project for a steal of a price. The car has about 200 miles on the rebuild. But first, a short story.
12/2007- He first purchased the car from a guy in Houston, TX. We got the car home, realized it was running on 3 cylinders, he accelerated his plans for the swap.
04/2008- Swap completed by a local shop. We attempted to do it at first but we ran into a few problems, some due to inexperience, some due to lack of tools. 4 days after the swap was complete, the engine overheated and blew a head gasket and cracked a rocker arm. The car was down for months before he finally decided to learn how to fix it. We also find out that the shop did a shitty job on the wiring harness.
Late summer 2008- We finally finished fixing the blown hg. Due to work and lack of motivation it sat for a while. 3 days after this the car jumps timing, apparently we screwed up when putting the cams back in. The car sits till late 2009.
07/2009- I move back from new jersey, kick my friend in the pants. He is debating between doing a rebuild or starting from scratch with a new sr20det. I convince him to go for the rebuild. We drop the block and heads off to the machine shop and have the following installed/done.
Block and head decked/hot tanked
.20 overbore
Port/polish heads
3 angle valve job
Apexi metal HG
ARP head studs
BC 264 cams
BC valves/retainers/springs
Clevite bearings
BC rods
CP 9:1 pistons
Rocker arm stoppers
