Results 11 to 20 of 46
Thread: Rebirth of my 94 R/TT - Single Turbo
    May I ask where you got it?
    Also, that looks like a marmon flange 1/2 moon.
    God I can't wait til you get it dynoed. I hear they make sickk torque!
    Lastly, what are you going to do about headers? Make them yourself or buy them?
    did jason finally make a plug/play harness for PROEFI on these cars?
    let me know when you're ready to buy injectors, im a dealer for ID, i'd recommend FIC2150's tho if youre planning on running E85. 1000cc's will only get you to about 600whp on ethanol.
    Quote Originally Posted by vr4_rider View Post
    I forgot what the seller was on the turbo. You can find them on e-bay sometimes. For headers I'm using GTC Metalworks headers. I already had them coated with 2000 degree black thermal coating.
    - Volvo V50 T5 6-Speed
    - Porsche Cayman S 6-Speed
    Quote Originally Posted by Gene View Post
    Apparently so, they don't stock them normally - they're building it for me.
    As far as injectors go I was thinking of upping the fuel pressure on the ID1000s, but if you can get me a good deal on some 2150cc injectors I might jump on those as I wasn't too keen on ramping up fuel pressure, although I have read that some of the Supra people have run them around 100psi and they are stable at that. The ID2000's are about $1400 shipped for a set of those. The FIC 2150s appear to be around $1100 shipped for a set of 6. My power goal is around 700 AWHP on E85.
    I'm also looking into meth/water injection for when I'm stuck running 93 pump gas. I'm hoping the ProEFI can also blend from 0 meth/water running E85 to full level of injection while running pump as it blends the two fuel maps together. It's one hell of a system and I'm excited to be running it in my car.
    TD04 Upgrade & Billet TD05 Upgrades
    Hudson, WI
    Nice looking build so far!
    Quote Originally Posted by TooFast4Radar View Post
    Did you test fit his setup first? I've messed with some of his exhaust work and all of it was crap.
    the injectors themselves are fine at 100psi base pressure, but you need fuel pumps and regulator capable of running 130+psi and thats not very common...
  8. #18
    The Welden external pump should do it and my FPR is supposed to go up to 125 psi, but matching a better injector is probably the ticket.
  9. #19
    yeah, going up to those pressures isnt ideal by far.
    you can bump the pressure up to 50-60psi base and the gains in atomization are great but i wouldnt go much past that.
  10. #20
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    Thatll be badass. The car looks awesome. Good to see another single turbo . Ive got a T70 that will be put in this winter.
