I don't see anything written up on here about it so I thought I'd share what I did.
Cruise control:
I used the same cable off the throttle and hooked it to my gas pedal. I had to file the one end down to fit the nut threw it. It also helped fit into the yellow clip on the gas pedal easier. I sliced the clip with a razor knife so I could take the old cable off and insert the new one. The rest is just unbolting and getting rid of the junk. I also moved the connector for the power steering tucked up under the wheel well. Now I have no wires showing at all on the driver side =) I know people will prolly hate me for this, but I just cut the wires for the cruise control and for the horn. I made them long enough in case I ever use it again but I don't plan on it so I chose to get rid of it.
Now for the AC fuse box, I took the box out and wired it into the driver side fender. No extending wires or anything. I re taped the wiring for the box and shoved it through where the main harness goes through. I plan on getting rid of the SRS so I removed the sensor and mounted it there.IMG_2106.jpgIMG_2105.jpgIMG_2110.jpgIMG_2109.jpgIMG_2104.jpg
