Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: o2 sim question
    what are the two others ?
    Cazenovia, NY
    Damn EVAP and EGR. I attempted to hook up the EGR lines in the hybrid manner, since I'm pretty sure my solenoid is a hybrid solenoid for some reason. But to no avail, still get the CEL for it
    those bitches are hard to deal with
    ~2006
    Pittsburgh, PA/Wheeling, WV
    Eh just get an EMS and call it a day
    Cazenovia, NY
    And absolutely never be able to pass emissions? I don't think so
    Cazenovia, NY
    I've been busy with my car and haven't posted back on this.
    I bought 2 20ohm20watt resistors to wire into each heater ground wire. It cured one of the o2 heater codes. So then I tried to eliminate one of the resistors and just wire both o2 heater wires to one resistor... same result.
    Not quite sure what the deal is here. I suppose the next step is to splice the one heater signal wire at the ECU into the other signal wire at the ECU and see if that fixes it.
    Just not sure why one went away and the other still remains.
    Cazenovia, NY
    OK.... nevermind the last post. I did some continuity testing with my DMM to find out what the issue is. Turns out I had the rear O2 heater wire mixed up with a different wire and it just simply wasn't connected at all. It's a bit confusing because the one O2 heater wire is black I believe... the other one is green/white. I realized my mistake when I noticed the wire at the ECU was green/white and had a "doh" moment. Swapped wires and the code is GONE.
    This is only using one resistor too. The directions say you must use two resistors, but one of mine got trashed so I tried with the single resistor... worked just fine.
  • History
  • Information
  • Groups
  • Events
  • Resources
