so driving home tonight I got a CEL
code:active
22(Crank Angle Sensor)
code stored
44(coil pack) rear pack not firing.
I have a jdm ECU so shouldn't having leaking caps? Is it possible?
Well I changed out coil pack and CAS with no results. Could the wiring to the CAS have an issue some where?
I was driving down the highway and it developed a miss and CEL came on so I pulled over and found out that one coil pack wasn't firing well I started driving and once I got up to speed the CEL went off and everything was fine until I got about 5 minutes from home when it started doing it again.
I drive a 92 TT
