Trying to get some issues worked out, I'll explain the problems and hopefully get some input from some of you.
It makes a sort of constant humming sound when driving straight and curving to the right above 40mph and louder the faster I go. If I curve to the left the humming goes away completely. Also if I got above 60mph the steering wheel starts to shake and the faster I go the worse the shaking gets. I recently installed all new suspension, cv axles, tie rod ends on the front end and replaced low rear control arm assemblies because the alignment shop said they were "seized" which they were.
I took it for an all wheel alignment after I did all of the above work and still have these problems. 2 years ago I replaced the wheels and tires and had them balanced thinking I was getting the humming from that but it was still there.
Hope to hear from someone.
Jon
