Results 1 to 5 of 5
Thread: AN Fittings
    Northern Virginia
    AN Fittings
    I searched around, but could not really find anything at all. Is there a fitting that is 90 or 120 degrees, that would allow me to connect 8an SS braided hose, but have a 10an female connector? So an 8an hose fitting that would allow me to screw the fitting onto a 10an male connection.
    You would need to do it with 2 separate fittings, as i do not know of such a fiiting. Get a -8 120* fitting, and the a -8male/-10 female adaptor fitting behind it.
    And the list goes on...
    Northern Virginia
    Correct on that one. I either need to do that or setp the oil cooler down to a 16 row, which already comes with 8 an fittings on it. Got a 19 row, which is 10 an at the moment, mounted in the stock location.
    The fittings aren't removable, we have a 8.5x11 core that accepts -8 fittings
    Northern Virginia
    Fits in the stock location? Limited to about a 6 inch height clearance in there with the FMIC piping. Could use a cooler that is thicker than 2 inches though, I've got clearance in that direction.
