Results 1 to 9 of 9
Thread: 1999 headlight bucket part number
    Hey, guys.
    Does anyone know the part number for the 1999 headlight buckets (L and R)?
    I was informed the 1991-1993 are the same. The 1994-1998 are the same. And lastly, there's the 1999 buckets.
    Also, my car is a 1993 RT/TT...I don't need the radiator support for the 1999 conversion do I? I believe 1991-1999 radiator supports are the same.
    Thanks,
    TP
    TN
    Are you asking about the headlight assembly or the headlight bucket support frame?
    Medford OR
    According to the interchange manual,(I would want to verify it with factory info) the 94-99 are the same. MB907980(R) MB907979(L) It also says the 91-97 upper core support are the same, with a different part# for 98-99 I don't remember for sure, some searching will probably bring up the answer, but I think that's just a radiator and mount difference... You should be fine on a conversion.
    Most of the info you need can be found at the 3SX faq: http://www.3sx.com/faq/99/index.asp
    Quote Originally Posted by dbest671 View Post
    I am asking about the headlight buckets and radiator support as seen here:
    According to this http://www.3sx.com/store/comersus_vi...?idProduct=564 and what you are saying, the 94-99 headlight buckets are the same (2nd from top from drop down box). Also, the radiator support center panel (last in the drop down) are the same for 1991-1999.
    According to this post by SteveVR4 (3sx) http://www.3si.org/forum/6067536-post8.html he says that there is a different bucket for the 1999 lights.
    I just want 99 buckets..haha.
    Charles Town, WV
    Quote Originally Posted by vr4_rider View Post
    My 99 headlights, turn signal, and bumper all bolted directly onto my 95 front end without any changes to the headlight buckets or radiator support. So if the 94-98 headlight bucket is somehow different from the 99, it doesn't make any difference at all once everything is bolted on.
    1995 VR4 Coupe
    I'm Kind Of A Big Deal
    I believe they are the same as the 94-96 stealth headlight buckets. They have a bracket that holds the turn signals up/to the headlight.
    Current:
    2004 ML500 - Mommy Mobile
    1995 3000GT VR-4 - lawn gnome
    1999 3000GT SL - 7,436 miles
    FOR SALE:
    Hey, guys.
    Thanks,
    TP
    radiator support is different. I can sell you the complete assembly if you're interested. (both L/R headlight buckets, and the 2g rad support). You will need to spot-drill our your old headlight buckets, and pry them off, then spot-weld on the new buckets, prime over the areas you welded to prevent rust, and paint to match your car/engine bay.
    PM me for pricing.
    Please PM me a price, Emilie. Include what year and model it came out of.
    Thanks!
    Thanks!
    I just saw this. I'll shoot you a PM in the morning with pictures/pricing. The headlight buckets are from a 95 Stealth R/T.
