you'd be better off just calculating it
Yep. Do the math. Take the car out. Go to 4000 RPM in 3rd, multiply times two. You have your answer.
I mean you could just plug the gear ratios, final drives, and tire sizes into any of the 1 million gear ratio calculators on the internet, or calculate it by hand with a little bit of math, but that would work too.
hell the formula is even on the page:
http://www.stealth316.com/2-gears.htm
Speed in gear (MPH) = [RPM x tire diameter in inches] / [final gear ratio x 336]
Thanks for inserting the formula... Made things so much easier since I'm using my phone.
My tires are 26.13". Reving to 8000 on USDM
3rd gear (209040/1613.81) = 130 mph
4th gear (209040/1193.81) = 175 mph
Man, fourth gear looks abnormally high. I calc'd 4th gear like 5 times... Seemed inflated but the math works out. That's correct, yes? Sorry guys, long day...
175 looks correct via graph
