so ive got a semi bad syncro on 2nd gear right now. i was thinking about replacing it, or buying a 6 speed trans. the prob is the 5 speed has perfect gearing for my car in the 1/4 mile right now since im right about at redline in 3rd as i cross the line. if i get the 6 speed i think ill have to shift into 4th gear which might cause me to loose some time. but what about the 6 speed with MR gears? are they short enough that i could grab 4th and actually use 4th gear?
I’ve searched stealth316 and cant find any info on the MR gears.
as far as i can tell (without any slips from the track) my trap speeds are more or less in-between the orange dots on the pic below. obviously my speedo / tach could be slightly off or my '1/4 mile' could be a little shorter or longer than 1320' but nothings an exact science on the street.
you can see the 6 speed's 3rd might be a little to short, and the 5 speeds 3rd is pretty good but what about the 6 speed MR? would it work just as good or maybe even better than the 5 speeds 3rd gear? anyone have any good info on it?
