Page 14 of 16 FirstFirst ... 41213141516 LastLast
Results 131 to 140 of 153
Thread: 6g74 route
  1. #131
    Quote Originally Posted by GTwizard View Post
    Love the sound Dude. 272 have the best lope I've heard. Like the sound of the exhaust as well. Once you dump those rich spots your in for a surprize.
    Well....I am looking forward to tomorrow then! cleaned up the map a bit....will be going for a spin and seeing how she goes! bit of on road tuning for sure.
    Exhaust was made in my earlier days when I didn't really do research into anything, just wanted things to be done....mandrel bent engine pipe, 3" high flow cat, 2.5" mandrel bent from cat back, then 2 x 2" press bent from the rear axle to two mufflers. Never sounded better though...
    Will let ya's know how it goes tomorrow. Just hope that oil leak was the rocker cover ><
  2. #132
    within the last week ive been noticing a real loss of power with my 6g74 around 2k-3k almost like the car bogs down and the rpm needle doesnt move up as fast. I'm totaly baffled as to whats going on here, really hoping you guys can give me some insight on what i should check out.
    Motor: 3.5 6g74, 3sx lw pulley, Maximal solid mounts, 8.5mm msd wires, Big tyla ground wires
    Drive Train: Spec stage 2, Rps lightweight flywheel
    Fuel: Ohhnoo ss fuel loop, TT fuel pump, TT fuel pump assembly
    Nitrous: Zex Wet EFI Nitrous Kit, zex bottle heater, Zex purge kit, Zex no2 gauge, Nos window switch, Weevil custom ashtray nitrous switch panel
    Managment: Autometer A/F gauge, Hand Held Halo dataloger, 3sx in bay fuel pressure gauge
    Suspension: Front and rear ultimate performance strut bars, Megan springs, Saleen wheels
    Intake/Exhaust: Generic cone filter intake and arm, Ultimate performance intake box, 3sx downpipe, 3sx test pipe, Megan catback
    look Good: 3sx plug cover, 3sx engine covers, Polished plenum, Polished valve covers, Polished fuel rails, 3KGT2NV allen bolt ss kit, 2g black garnish, Rear active aero transplant, Jdm snake eyes
    Interior: Custom two tone leather, Pioneer dvd, Alpine speakers, Alpine 4way amp, Ultimate performance door sills, Razo shift knob, 3sx Aluminum Pedal Covers, dual piller pod
    wasting my money on a NA since 2009
  3. #133
    How's your oil pressure?
  4. #134
    idk, how the oil pressure is couldnt get the damn gauge to work
  5. #135
    Only aftermarket gauge I have running right now! Very handy to have....a 5psi drop alerted me to an oil leak...
  6. #136
    Quote Originally Posted by jessecain1 View Post
    Lots of these 3.5 swaps fail because they are running a stock 3.0 ecu. It seems that the timing is too far advanced and it causes the engine to kill itself. Mine did it in my satin black car. Spun a bearing in only 3000 miles.
  7. #137
    whats a remedy to this problem?
  8. #138
    is this just a problem with 74's, or are 72 strokers prone to this too? and yes, what's the solution (other than AEM)?
  9. #139
    at this point im really hoping i just need to clean my iac
  10. #140
    If you have a 91-92 CAS, you can try adjusting your base timing and then log it to make sure you aren't knocking. For 93+ models, you would either need a piggy back timing controller like an emanage or swap to a flashable ecu. You may even be able to find an ECU that matches the engine if you search hard enough.
