Anything from a stock replacement to dual walbros or Densos, and easy to install!!
These are currently in stock and ready to go.
They will allow you to use 1 or 2 pumps, Walbro or Denso (supra, stock, Kyosan, etc) and include theyre own independent power/relay wiring harnesses (commonly referred to as a Hotwire kit, but this is so much better i dont want to call it that). Each pump has its own dedicated circuit from the battery + to the pump, and back to Battery -
Yes, you read that correctly, you can use 2 denso pumps without modifying the tank hole!
- Kit includes comprehensive VIDEO instructions
- All electrical components are rated at 40amps. The wire meets SAE specs for automotive underhood use.
- Wiring is sealed through the bulkhead using Chemical resistant epoxy potting compound
- Harness and pump frame are terminated with professional grade connectors and pump can simply be unplugged for easy removal
- The pump hangers are constructed of 12gauge steel and Zinc plated
- Each assembly has two #6 an feeds and a #6 an return
- OEM Fuel gage and warning floats remain in place
This is what you get for $325
If you want to use this as a stock replacement because yours is destroyed or damaged, i will include a kit that will allow a single pump and use all the stock hardlines for an additional $10. The kit includes a feed hose and caps for the unused AN ports.....SOLD OUT
Please specify if your battery is in the front or rear, and if you need the ten dollar single pump option
Please note that even if you get the single pump option, you will still be able to upgrade at a later date to 2 pumps without any additional parts, everything to run 2 pumps is included in every kit
Dealer Inquiries Welcome
