Page 16 of 23 FirstFirst ... 61415161718 ... LastLast
Results 151 to 160 of 229
Thread: 99 Montero ECU, 92 Stealth TT
  1. #151
    July 2005
    Arkansas
    Hotwired fuel pump is one of the things needed, and the stock boost gauge wouldn't work, last I heard, but that was a number of months ago. I don't know if any effort will be put into those, since most people going with a flashable ECU would already have the FP hotwired and an aftermarket boost gauge.
    This is not true. The fuel pump does NOT need to be hotwired. Vira's car runs just fine with a 99 Montero ECU and adapter harness, without a hotwired fuel pump. IIRC the hotwired fuel pump thing came up from the later single chip ECUs that combine the TCU and ECU chip into one. Jeff can elaborate more, but I know the fuel pump does not need to be hot wired.
    Active Aero should work, because I dont think there is any hardware in the ECU that deals with active aero since it has its own computer. Active exhaust is missing components so it wouldn't work, along with the stock boost gauge and a few other things like stock boost control.
  2. #152
    Charles Town, WV
    Quote Originally Posted by aaronatstate View Post
    Oh, excellent, I hadn't heard about it running without a hotwired pump. I may move this up on my list, since I've got the 98 montero ECU waiting to be modded, but don't have an AFPR yet to do the fuel pump hotwire and it's too cold to be running wiring from battery to trunk in the snow, and I was going to replace the pump while I was back there.
    Jeff is doing a FANTASTIC job on all of this.
    1995 VR4 Coupe
  3. #153
    Monterey Bay, CA
    Thanks for the info. I doubt too many people are going to be concerned with losing the stock boost solenoid / boost gauge. For me, I removed the solenoid years ago, and if the stock boost gauge stopped working tomorrow I probably wouldn't even realize it. I can't remember the last time I looked at that gauge.
    I'm not sure if you're willing to tell us (and understand if you're not), but I'm just curious what modifications need to be made to the montero ECU to get it to work?
  4. #154
    I lack color... verified
    Aug 1998
    It'll run w/o a hotwired pump but the relay will never switch to lower the voltage. Nothing really to be concerned about.
  5. #155
    July 2005
    Arkansas
    560s got here tonight, will be installing tomorrow morning, then going out to do some runs at current boost, then its time to turn it up.
  6. #156
    July 2005
    Arkansas
    Installed the Evo 560s this morning. Flashed the ECU and the car started and idled like it was stock.
    Went out and did an initial test drive at the same 14-14.5psi I had it set at. Only thing that changed between the logs, like I expected, was the IDC. It dropped 20%. The AFR and everything else was nearly identical. Here are some videos.
    First Start
    After initial test drive.
  7. #157
    Still keepin the faith!
    Ready for you in july after NG.
    __________________________________________________ ____________________
    Tapatalk Bitches!
  8. #158
    I don't bite
    Southern IN
    So when is this going to be available to the rest of us, instead of being tormented and teased with your results?
  9. #159
    July 2005
    Arkansas
    I'm not sure, I wasn't doing the hardware side, Brett was. I know he's going through a lot of crap right now, and this got moved to the back burner for him, but he's still working on it.
    I got my car tuned at 18psi, and its quite fun now
  10. #160
    July 2005
    Arkansas
    Set the car to 18psi now. I have to play around with my Profec some, cause it was only holding 16.5psi to redline. I'm not sure if its the EBC or possibly the wastegates getting blown open. I'm going to play around some more, then try to adjust the wastegates if I determine its them. I know you can adjust the end, to effectively make the rod shorter.
