Results 1 to 10 of 16
Thread: Digital odometer conversion ?
    Anyone have done it ? I need to change it into metric system and I really want to have digital odometer . Any ideas ?
    You'd likely have to go full custom. Its something I would consider doing myself as a future project.
    Dakota Digital makes all kinds of digital gauges. I know there are more but they are the most prominent from what I have seen.
    Yes they do make nice guages, you will have to take out your stock cluster and either cut a hole and put in one guage, or remake the entire panel with all digital guages, which would be pretty cool.
    And the list goes on...
    Part of the "Flipped Your Car Club" verified
    A few people have done it before. Not many.
    I'm not sure how easy it was.
    1992 Stealth RT/TT
    Condition: Totaled(In Process of Rebuild.)
    Oct 2010
    Ukiah, Ca, USA
    oh its not that easy. You consider all the idoit lights that go into that gauge and the gas tank and then RPMs and Speed. Most definately can be done, but never cheap. However get a bunch of people interested in it en masse and it can be done. Ive been looking into it and using something like my gsxr had with the rolling tach and digital spedo. however im a sucker to watch that needle go whheeeeeeeeee. problem i have with digital gauges is you MISS things. Im always about analog for making sure shits going how its supposed to. When you hit digital hard, it just skips certain spots and you dont get to see if its smooth or not.
    -dLs- :twisted:
    I already have quite nice gauges yes I know 11k is a bit too much
    there is no visible redline when its dark because the whole rpm face truns red @ 7200
    Something like this
    Oct 2010
    Ukiah, Ca, USA
    ohhh, okay. So digital for milage for multiple read outs and is that RPMs on the top bar?
    -dLs-
    Yep digital for mileage
    Banned J. Fast's Avatar
    THose gauges look really sweet! What do you want the mileage to start at? Zero or current? You could use a cyberdyne speedo sending unit and then wire the sender into a digi gauge for tach, mi, and etc. http://www.summitracing.com/parts/CY...n/?prefilter=1
    mileage should start at current
    thanks
