Results 1 to 1 of 1
Thread: WGDC Delay Timer
    Nov 2013
    Stockton, England
    WGDC Delay Timer
    Can someone advise me on how to add the WGDC delay timer table menu in the Turbo sub-section of ECUFlash please?
    I have a 3 port boost control solenoid but think the timer is not helping with my particular issue.
    TIA
    I'm asking as the original help pages in the Chromed manual reference it:
    'The WGDC correction algorithm operates on timer and I have found the delay time setting that sets interval between WGDC corrections! The stock value is 10. The scaling appears to be 1 unit = 0.08 sec, so 10 units is about 0.8 seconds. This is how often it updates the correction. Since the stock BCS isn’t nearly as responsive as some of the aftermarket solenoids out there, there’s really no point in changing this.'
    I presume that it needs to be added to the EcuFlash XML file so that it appears in the Turbo menu when I load the ROM.
