Installed eightyzips shift & handbrake boots. They look amazing and while the install was fiddly, it went smoothly and they installed well.
Pretty cool, Ken...
Working on a copy of the GR86 Cup car hood vent... an expensive print to reproduce at a print shop, not too bad at home but a bit annoying. I'll print it in ASA on my Ender, it's too big for my Method even split into three pieces. Annoying because the Method has way better surface finish but oh well.
STI Performance Muffler & STI wing arrived today! Threw the muffler on real quick to replace my CSG Touring 86. It's too quiet inside the car, but I am so excited to do a mid pipe & front pipe to open it up now.
As they say, Ken, if I had your money I'd throw mine away.
I don't know how loud you want it, but for me I think it would be pretty much spot-on.
How much power you think you're making?
Installed a JDL Ultra Quiet frontpipe today, I found a gasket that works to adapt from 2.5" frontpipes to stock midpipe, which is nice
Walker 31398 fits perfectly with no hassle, but does have a smaller ID (which is about the same as the stock midpipe anyway)
If you want to dork around cutting some of the gasket's built in metal flange that fits into the frontpipe, a Walker 31554 "fits" as well if you cut away most of the metal ring so it only has a few tabs left to center it/support it in the front pipe. It seals fine and all, just know it's a bit of a hassle up front for essentially no benefit. The other gasket wasn't available locally to me so I did this
NNJR Autocross from last weekend! I finished 4th in PAX and had a friend from *way* back in my 3000GT days codrive, his first time in a proper ST car after years of the wrong DS car
My fastest run:
Sang's fastest:
Not the greatest pics... I've gotta clean up the car and install a little longer front studs before I can go anywhere for better pics. Only 5.5 turns of lug nut engagement with 13mm front spacer compared to the 10mm spacer I was using before with the Enkeis, not quite enough!
These are the APEX VS-5RS, 17x9 ET48
Replaced my Eibach front studs with ARP for a bit of extra length for more spacer options, mostly so I could run 13mm front spacer for my new wheels.
Found a shredded A052, sadly. I was hoping to use the rest of this (very bald) set of tires for a Track Night, oh well.
New wheels installed with 13mm of spacer up front.
A couple more Philly events in the books! I killed a set of tires at this one in April. Finished 8th in PAX.
Sunday there was another event, super challenging course and I think I just had a bad plan for the course. Finished 7th in PAX
