I have a 1991 R/T Twin Turbo Dodge Stealth with 16,000 miles. I went out to start the car and the clutch pedal wouldn't go to the floor. You can pump it and it will go down about halfway, but that all, feels like a spongy brake pedal. Since I can't depress it to the floor I can't start the car, and I can't bleed the system either. I've checked the vacuum line off the plenum with the check valve in it, it works fine. There are no leaks, and from what I can tell the slave valve is working as it should. What so odd about this is I just took it for a drive two days before. So this happened after I had driven it.
Any help with this will be greatly appreciated.
Jack
