Originally Posted by
mc24
Yes car was running fine on stock injectors and 15 psi boost and stock ecu. Just added some billet 15g turbos and the 550cc injectors and the chrome ecu. I have been messing around with the ve smoothing table and have all the trims with in 5% but injector scale is still at 420. Had to add like 20 or so on the ve smoothing table 100hz and below and a few on the mid to get trims with in spec. Im assuming my injector scale needs to be way closer to the 550 but car will barely run its so lean when set to that.
