Alright guys, I have been trying to get this figured out over the last few weekends and I am at a loss.
Upon doing initial diagnosis of things on the car I found a few things not working. The last thing I have to correct is these reverse lights. I have power at the fuse, but no power at the plug on the trans. To make things even more confusing I no continuity from the trans plug to the plugs at the reverse lights.
I've looked over the schematic and only see 3 plugs that would be at fault. I wasn't able to locate the 19 pin plug on the passenger side corner area of the dash before I called it quits. The other two plugs are on the junction box above the fuse box and other than trying to get a visual on them being plugged in I did not get to test them because I couldn't figure out a way to get to them without removing the whole dash.
I've literally got my car half disassembled again. I pulled the fenders back off hoping I could get to the plugs through the holes that the body harness passes through. I pulled my glove box trying to find the 19 pin plug in that area.
I'm ready to pull my hair out. This is the last of the issues I need to fix before I can really start moving forward in leaps and bounds. Hoping someone can offer some help before I can get back to the car.
