Results 1 to 4 of 4
Thread: Idle switch always 0 in evoscan
    I've been going through the chromedecu getting started guides and got to the idle section. I noticed at idle that my idle switch was always reported as 0 by evoscan.
    I've performed the following tests:
    - rotated the throttle position sensor fully forward, and fully backward without seeing the idle switch change state in evoscan
    - measured the resistance between pins 3+4 and found that the switch opens correctly when i rotate it clockwise (see here)
    - manually shorted pins 3+4 on the harness side without seeing the idle switch change states in evo scan
    - measured 5v between pins 3+4 (so its connected to the ecu probably)
    - the tps reports a value of 13% for the throttle position at idle
    I haven't tracked the wires down to the ecu yet to verify, but does anyone have a guess?
    Medford OR
    It's going to be Evoscan... Set your idle switch to request BA, X bit 1.
    I bet it's set to X bit 128...
    You're right, it was. Is that an error in the xml? I just downloaded it from the chromedecu site recently.
    Medford OR
    Quote Originally Posted by q2418130103p View Post
    I guess... Seen it several times. Greg pointed it out and gave the fix in this thread:
    https://www.3sgto.org/threads/12068-...he-proper-way)
