I had two error codes on my 96 3kgt SL automatic.
#1 Cylinder 4 misfire
#2 P1750 (Transmission Solenoid problem)
I had a hard time shifting between gears (gears would be rough but would shift). First gear didn’t give me problems but the other gears would have a hard time shifting on hills. And the engine would rumble because of only running on 5 cylinders.
So I parked my car and replaced all the spark plugs (front and rear). I had to take off the intake manifold and throttle body.
When I put everything back together, the car wouldn’t shift at all. You would have to get it to go in high rpms to get going. (This was before draining the tranny fluid. )
I then replaced the tranny solenoid pack and the P1750 error code went away. The tranny fluid was drained and replaced. (Not flushed out)
It still had the loss of power in the drive and 1st gear doesn’t have any power. You only get power when you give it a lot of gas.
Once you have a high enough speed, you can let go of the gas and it’ll fall/shift into 2nd gear and then it drives like normal above 1st gear. The bumpy/struggling shifting is gone and it shifts wonderfully. When it’s in the air, it shifts fine in 1st gear. But when you put torque on it, it doesn’t have any power.
Reverse works perfectly as well.
The Throttle Position Sensor works just fine and has a current flowing as the manual says.
I adjusted the throttle cable as well.
What could possibly be the problem? I don’t think it’s anything with the transmission because it started acting up when I removed the intake manifold and throttle body.
