I've just started the tuning of my 3000GT engine in my kit car running a Chrome ECU. Starting with the idle setting as recommended in the guide and fell at the first hurdle. With the idle wire connected the base idle is low so I adjust it up to 850 (as set in the ecu) and it runs quite smooth. As soon as I disconnect the wire. idle goes up to 1100rpm. So I figured there must be something wrong with the idle control valve. Took it out and sure enough, pins 4-5 have no resistance. I made sure the valve is fully out and refitted it but left the connector off; still the same problem.
Any ideas folks?
