Instead of burying this question in my resurrection thread I figured I'd make a new thread. Hoping Larry or Steve sees this.
Ok, so to recap the car is a 91 3000GT SL and still has the 3000GT body harness. The engine is a SOHC. The ECU and engine harness are from a 94-95 Fed Spec SOHC.
The issue I am running into right now is for the radiator fans. I knew all along that the 1g's had the sensors in the radiator. What I didn't realize was the harness for the sensors was incorporated into the main fan wiring harness and the 1g main fan had a different plug.
Now I do have a 1g fan to use, but my question is how do I tackle this? I have the sensors in my coolant neck and they are plugged into my engine harness.
What do I do about the other sensor plugs? Do I need to get the rad sensors and install them and have redundant sensors? Can I just splice the 1g plugs into the 2g wiring? Do I even need to do anything with the 1g plugs other than tie them off since I have the 2g engine harness?
