Results 1 to 6 of 6
Thread: Chrome and nbo2s
    Forum User Feedback Score 0 FluffyCow's Avatar
    West Islip, NY
    Chrome and nbo2s
    I know you can disable one or both nbo2s in chrome. If I disable the front, running off just the rear, does that set both front and rear trims off the rear nbo2, or does it stay locked at the prior nbo2 trim setting?
    Sent from my SM-G955U using Tapatalk
    1991 Dodge Stealth ES
    - Sold
    1991 Fiji/Mystic Blue R/T TT 1 of 235(paint/R/T TT only, can't find more info, VIN is a 1 of none number)
    Sold.
    1992 silver VR-4 - 1 of 152 identical
    Show: 99 Sails, 99 rear garnish, 2nd-gen steering wheel, Pioneer Premier h/u, aftermarket speakers(Alpine type s's I think), 10 inch JL W1 sub in spnallb corner box.
    Go: 15G Turbos, FMIC, ATR DP, ACT clutch, 3-inch turbo back to dual apexi N1 mufflers, no cats, HKS SSQV3 BOV(black), PWR rad, Ksport coilovers, 3sx rear adj. control arms, ChromedECU, ECU Boost control, rebuilt TB, Cianci gauge pod w/ Defi D-series(Boost, EGT, oil pres), 93 shifter.
    Soon: 550cc injectors, ChromeTune, boosties!
    1987 Dodge Ramcharger - The back-up plan/winter beater. Mods: Non-computerized timing, custom white gauge faces and red LED illumination, cat-back straight pipe, Chevy seats, Ford running boards, and MOPAR everything else.
    Wife's ride: 2014 Hyundai Sonata 2.0T Wifeboosties, go!
    Family-mobile: 2016 Dodge Grand Caravan. Dogs love minivans!
    Member Not Verified Feedback Score 2 (100%)
    Sets both to rear. IIRC even without chrome the rear sensor is primary so just unplugging the front will set both banks to trim to rear sensor, but it sets a CEL. I did this back when I ran the MAFT-Pro and used the wideband's narrow output and plugged it into the rear sensor wiring. I chose the rear because the rear bank seems to run leaner (4 and 6 specifically) on most 3s's.
    Feedback Score 1 (100%) Greg E's Avatar
    There is no logical reason to disable one of the NB sensors....
    West Islip, NY
    I've tried everything to get my front trim to stabilize. New nbo2, checked wiring, stock injectors, new 550cc injectors, swapping back injectors to front,swapping nbo2s from front to back. Front just will not stabilize. Don't have any exhaust leaks either.
    What's the front LTFT doing?
    West Islip, NY
    I'll have to go back to my logs, but I don't recall it doing much of anything. Mid would move a little depending on where the stft front would decide to do
