My car is a ‘96 3000GT SL
So a while back I got the error code P1750 that said Manufacturer’s Error Code (or something really similar). I looked it up and people said to replace the solenoid pack on the transmission.
So I took the transmission fluid pan out, the filter and removed the valve assembly to get to the solenoids. I replaced the solenoid pack as per instructions on the new part’s manual.
I put everything back together and filled it with fluid again. When I tried to start it, it won’t start in park but I have to move it to neutral to get it to start.
When it is running, it won’t shift into reverse or drive. When I turn it off and put it into park, the shift stick gets really stuck and I have to push super hard on the breaks to get it to shift back into neutral.
My dad said I may have put something in wrong, but I can’t think of anything I did that would be wrong. Everything was put back the way I pulled it out.
Can anyone explain what’s wrong?
