Requirement: LCDBC product, and is running version 3.00 software or newer. A software update will be necessary on the LCDBC unit.
This new OBD1 or OBD2/MUT cable is capable of reading all 8 computers on our vehicles, such as:
Engine ECU, Transmission ECU, Suspension ECU, Digital climate control ECU, SRS (airbag) ECU, ABS ECU, ETACS, Cruise.
Basically whatever the factory scan tool could do for our cars, now your LCDBC can do also. That includes reading air bag codes, clearing SRS light (and code), perform diagnostic tests on your ABS, etc.
Current inventory as of Sept 3: 1 units
Priced at $130 USD shipped to USA / Canada. For International customers, they will be shipped airmail without tracking, if you prefer tracking please add $30 USD. After you send payment, please reply back so I can update this list. I am building new units every day.
Paypal email address: antero_jussila@yahoo.com
or
www.paypal.me/LCDBC
F.A.Q.
(1) Will this work in conjunction with the C3 Climate control screen? Yes it does, as it only replaces your existing OBD cable.
(2) I have 91-93 car, and a 98/99 conversion harness with a second OBD2 connector, what cable do I need? OBD1 cable with DB15 connector, and your existing old enhanced OBD2/MUT cable will be re-used -- insert this into the DB9 connector of the LCDBC addon.
(3) I have a 91-93 car, and a Jester/Chrome kit with the OBD1 plug modified with additional pins, what cable do I need? OBD1 cable with DB15 connector.
(4) What software version do I need to be running as a minimum on the LCDBC? You need 4.0 firmware, any unit that has 3.x firmware is upgradable to 4.0.
http://lcdbc.xp3.biz/updates/UPDATE403.zip
(5) How do I check the software / firmware version of my current LCDBC unit? Hold down the rotary encoder button during power up, and it will briefly greet you with a copyright message and version number.
(6) Where do I find user manual? Here's an incomplete manual, it will be updated as I find time to write more. http://lcdbc.xp3.biz/LCDBCADDON.pdf
