Hello,
Long Story short. Have both a Base Stealth(SOHC) and Base 3000gt(DOHC), 3kgt is rusted to hell and back but the motor runs great and I am in the process of stripping all the remaining good stuff out of it.
My Stealth is SUPER clean body wise, but has a blown head gasket. Planning to try to fix that... but in the case that its non fixable I wanted to ask what I should save from the 3k DOHC to swap it over. Obviously want to do all the maintenance items while it is out but what do I need besides engine harness?
edit: Both are auto-trans cars. Would like to do a mt swap but thats a ways away since I have none of the required parts for that yet.
I got this list from 3si forums:
Complete dohc engine with all accessories including throttle body and fuel rails.
Exhaust manifolds
Engine wiring harness
Dohc ecu
Fuel lines from frame up to fuel rail or just the pressure line, return line is just cut to fit hose
Power steering high pressure hose and reservoir
Ac line from evap to compressor
Heater hoses
Swap oil pressure sender over to the DOHC if you want your guage to work
Is that all I need to keep? Once I'm done stripping the 3k it will be going to the junkyard unfortunately... the frame is just toast. Just want to make sure I keep anything I need for the swap.
