As I try to get the SOHC running in a DOHC chassis I am sure I am going to run into a few issues I'll have to figure out and may need some help. I'll ask those questions as they come up but I do have one for now.
When I got the 94/95 Fed Spec SOHC harness and ECU off Greg I noticed two wires near the check connectors that were cut short. I figured at that time that I would handle it later. Well, later became much later, and after I got the harness installed a few weeks back it came back to my attention. I looked at the wires and noted they were a green wire with white stripe and green wire with red stripe. I dug my original Cali-spec harness back out and found the same two wires, and they were about 4 feet long, but to make it even more confusing, there is no plug on the end of them. They are ran through black "tubing" and just end.
I did some quick searches through the electrical manual and have come up empty. The only green with white I located has to do with the front combo light, and the only green with red has to do with ABS.
I don't know if these are SOHC only wires, but if someone can take a look at their harness or knows what the hell these are for please let me know. I'll take a look at the TT harnesses I have here too when I get a chance.
Thanks in advance
