i’ve been thinking about a diffuser.
i’m between buying one (for a 350z, r32, or r33), And attempting to make one.
if i bought one, i’d be looking at 3 or 400 dollars + whatever modification expenses; where as if i make one, i could probably spend a third of that.
realistically, i can’t really know how it will perform, so why spend so much money?
so, i’m leaning towards making one, but my question is:
how should it be designed? should i just try to make it smooth from around the rear diff, and possibly curve up a bit towards the aft of the car?..
some of the pictures i’m seeing have an opening near the top of the diffuser(as seen installed on a car). should i attempt to get air to exit above the bottom of the diffuser?probably via ramming air in through ducts or something.
and should the exhaust be above the diffuser, or cordoned off in its own portion of the diffuser?
my problem is that i don’t understand the physics of it. high pressure above low pressure creates downforceż i just don’t quite get it. may i have some elementary level explanation of this phenomenon?
thoughts? pictures and diagrams/schematics, everything is cool
_isiah
