Results 1 to 9 of 9
Thread: Chrome ECU - VE Table Tuning Confusion - Greg E
    Never finishes any verified
    Wake Forest, NC
    So I need to get a straight answer on this as it is driving me nuts. In the MAF smoothing "VE Table" which directions does what??
    In Greg E's doc here he contradicts himself as to which does which - > http://www.3sgto.org/threads/10775-H...nd-a-Flash-ECU
    so if your low trims are negative, you need to take away from the numbers in the 100hz cells and below. If they are positive, you need to increase the numbers.
    Later on he states:
    Say, for example, your Low trim Front is -10.6% and your Low trim rear is -2.8%. We want to get that front trim back above -5% but not going so far that it brings the rear trim out of spec either. What this means is we want to add at least 6% more of fuel to bring that trim within spec.
    So in both cases the trims are negative, one example he is adding to the VE table and the other he is removing from the VE table.... Which is which!!
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Forum User Feedback Score 3 (100%) Unlogic's Avatar
    Oct 2011
    Sundsvall, Sweden
    Higher values in the VE table means more fuel. If the trims on your LCDBC read below 100 reduce the values in the VE table for that range.
    Wake Forest, NC
    Yeah I talked to Greg E about it on facebook and he mentioned the mistake. The problem is the forum will not allow him to go back and edit the post to correct it. Going to try and reach out to Alan to fix the issue.
    Monogamous Gigolo verified Feedback Score 8 (100%) 2fnloud's Avatar
    He is on Vaycay, it could be a bit.
    Wake Forest, NC
    He's always on Vacation.....
    I lack color... verified
    Feedback Score 1 (100%) Greg E's Avatar
    Aug 1998
    Took a vacation 2 months ago... first one in 2 years!
    Forum User Feedback Score 0 FluffyCow's Avatar
    West Islip, NY
    sort of necro bump here. trims pegged at +12.5% in evoscan. should I be adding to ve or subtracting? I took some away based on the stickied post, but now I'm thinking I should be adding?
    Sent from my SM-G955U using Tapatalk
    1991 Dodge Stealth ES
    - Sold
    Sold.
    Aug 1998
    You should be adding.
  9. The Following User Says Thank You to Greg E For This Useful Post:
  10. #9
    West Islip, NY
    That explains why my wb went richer after I took away. all that's moot till I get an afpr that works though
