Results 1 to 10 of 25
Thread: Infinity ecu
    Apr 2015
    april 2015
    woo
    Infinity ecu
    Have chrome ecu but am wanting to upgrade preferably to a aem infinty . Its not plug n play but there is a patch harness available . Just wondering if its been done yet and with what series of infinity 5 or 7 . I know aem doesnt support out crank signal pattern but read that they or someone offer a new disc for the 1g cas that u can switch out . Just want to know has anyone heard of anyone actually doin this or actually done it urself . Ive already contacted aem to see what problems i might have but waiting for a reply from them now
    Apr 2015
    april 2015
    woo
    Also what dia. Is the stock cas disk ? There a 24tooth disk for dsm cas that i think will work but need to know dia. Of the 3000gt factory one to be sure . The infinty ecu has universal 24tooth 1cam pulse setting so as long as i have that disk i think i can make it work
    Look into the series 6. I make conversion harnesses. I was talking to guy that plans on using the series 6 and he wanted me to make a harness for it but I don't know enough about it to do it. But he said it's the most compatible with our cars and can read our crank angle sensor. However I did find on eBay someone that makes the conversion harness for the series 6 to be used in our cars. I'll find the link again and post it for you. Should you be interested in that or maybe you can to them and get more info on the series 5 an 7 and maybe they can make a harness for that.
    J.R.
    Apr 2015
    april 2015
    woo
    Series 5 is the 6/8 its bsically how many cylinders it can control like the series 7 can do up to v12 or v6 with dual injector setup. Have already contacted aem n they dont support 6g72 crank pattern but if i change the disc inside cas to a platform that they support then it should work .....i think . There is a available cas disk for the dsm cas and i basically need to know if i can use one of the aftermarket 50dia 24tooth 1cam pulse cas disk in my cas housing . I think that they support a 24tooth 1 cam pulse cas disk .
    best bet is to take a 1G cas and open it up and measure. I wanted to do this too, but stuck at the moment. I wish aem would just update the firmware to support us. I love the series 2, but don't want to get left behind.
    Apr 2015
    april 2015
    woo
    Thats exactly why im tryin to go this route . I just measured it its 50mm stock little less than 2in on ruler but ive read conflicting info on the part that mounts the disk to shaft its like a D shape but im guessing it will need to fit that perfectly . I might just buy the damn 40$ disk n see if it fits. Im guessing it will since most the cas all look alike . Im surprised aem doesnt support the 6g72 platform n just offer the cas disk with ecu like they do for the nissans. Or different cam/crank trigger disk for use with our cars . They support the dsm with infinity i believe why not us !
    Apr 2015
    april 2015
    woo
    Apr 2015
    april 2015
    woo
    Talk for a while yesterday with aem and looks like it will work gotta buy the 24 tooth cas disk which i confirmed with yoshifab that it will fit our crank angle sensor . So basically just need to purchase ecu n have someone make a harness . I do like the quality of the harness that boomslang.com makes . Once i acquire all the stuff i need i will post back to let everyone know that it works and what it took so this thread doesnt end up not finished like half of the ones on the net about this subject .
    Apr 2015
    april 2015
    woo
    Just bought the aem cas disk for the nissan 240 its 50mm diameter has 24 outer teeth and one inner cam tooth . But its fits our cas perfectly . So now i just gotta decide what route i wanna go with for wiring the aem infinity
