Monday, Tuesday, and Wednesday were all a washout. Finally got some decent weather to try to get some things done after work. I essentially got nothing done despite that.
I did get the front subframe out of the Stealth and proceeded to try to get it in the 3000GT. It refused to balance for me and when I thought I had it started on the studs good it fell and actually scuffed two spots on the bottom of the firewall. It wasn't too terrible but it pissed me off none the less. I actually grabbed the paint can and a small paint brush and touched up the scuffs. I finally found a balance and got it started over the studs but was unable to get the steering shaft to go onto the rack.
I had the same trouble when I put the subframe in the Stealth and my uncle and my cousin ended up stopping down to help me get it all aligned. I'll end up needing to do the same thing again. I also need to make sure the rack is centered.
Anyway, after my battle with the subframe my project jumping started again. I dug out the engine harness. I got the rear LCA bushing brackets out and resprayed them so they'll be dry when I install the suspension. I also grabbed one of my coilovers and went at trying to clean it up. I think I'll be able to clean them and make them look good while still assembled. They won't be perfect, but will look good enough for what you can see of them.
That's basically it. A few things "done" but no real progress made. Nothing will happen tomorrow due to bowling. The weather will probably be a factor this weekend, but looking at the forecast I should be able to get a few things done Saturday morning/early afternoon before the rain sets in. Hopefully I'll get enough done to make it worthy of a pic post.
